Removing rear driveshaft donut
as I can’t tow my xj8 to the gearbox shop as it’s an auto I’ll need to drop the rear driveshaft joint to allow it , for all the bolts out but the donut is secured with the shafts center shaft , do I need to drop center bearing to get the rear flange room to pull away from the diff
sorry biut all all the QA. It I’m new to Jags ....
zagamuffin (06-21-2018)
Hi Avern ,
damage to sispension ??, you’ll have to explain that please as can’t get my head around how the suspension knows if it’s poeered or not
I do understand that autos can be damaged as the box is spinning due to diff feedback but no pump is running so oil starvation can occur
I disconnected drive shaft to isolate auto box from drive source
cheers for the feedback
Jaguar does not have anything under the vehicle for an attachment point of tow hooks. The winching onto a flat bed will not damage the transmission. Towing the vehicle with the wheels on the ground for a distance can damage an automatic transmission. I am not positive that applies to the ZF but does on the older GM and Ford transmissions.
Winching on with tow chain hooks from the front or rear will damage bushings and linkages that are not designed for that stress.
Jaguar has a tow hook location front and back for a flat bed recovery truck.
so what im doing ive done for years and maybe not explaining corectly,im going to tow the jag with another car @ 10 miles to the gearbox repair center using a bar connected between tow cars and jags front and rear tow eyes under front and rear bumpers respectively.
ive disconnected the driveshaft as you say correctly you cant tow an automatic normally but as i've isolated the gearbox from the road wheels its ok....
AllanG
02-04-2014 07:21 AM
swoop22
10-31-2011 03:19 PM
cincinnati
10-31-2011 03:12 PM
