Replace 2000 Donnelly mirror with 2004 Gentex Mirror
My Donnelly mirror, like many, has succumbed to the liquid failure. Instead of having it repaired or taking my risks with a used one I decided that a Gentex replacement would be my best bet since its more readily available and considerably cheaper.
Pictures > Words
Broken Donnelly on the right, Gentex on the left
The mounts, Gentex is round
Cut both mirror mount ***** off with a hacksaw
Attach them. Mine is welded, however JB weld or a metal epoxy will work just fine for this task. There are some other options, like a roll pin that would also work if you do not have (or have access to) a welder.
Paint to match
Wire it up
Mount and done - $25 well spent.
Pictures > Words
Paint to match
Wire it up
The following 5 users liked this post by Probesport:
andrew lowe (04-06-2016),
D. Fite (04-08-2016),
DimitrisBXL (04-08-2016),
Don B (04-06-2016),
wrd0225 (06-25-2017)
andrew lowe (04-07-2016)
I had a Gentex mirror set up using this method temporarily until I was able to repair my original - the Gentex mirror stuck out a bit further than OEM (mostly my fault when building) and I don't believe it had the auto headlights feature. I actually have the pinout for my gentex, ill pull it up at the end here. The gentex I had was GNTX-177 which has the compass and temp features. The compass is a separate module you just need to sticky tape somewhere, and the temp gauge seems redundant (climate controls have it) so I didn't bother to wire it.
I repaired my Donnelly since I wanted the auto-lights feature... Naturally it doesn't work for some reason, but the mirror's been fine so far.
Pinouts:
gentex
1-12v ign
2-ground
3-reverse interrupt
4-outisde +?
5-outside -?
6-temp sensor
7-temp sensors
oem
1-white-+12v ign
2-grey-reverse interrupt
3-blk-ground
4-yellow-"cell"-
5-green-"ti s"-
6-brown-"hood"-
The pinouts will be different for the OEM if you have a 00+ or rain sensing I believe. I don't remember what pins 4 5 6 were on the OEM, I think those bits in quotes were from the circuit board inside the mirror. My guess would be that "hood" would be the auto-headlights output. One of those will be the outside mirror feed. Not sure about the remaining one.
Pinouts:
gentex
1-12v ign
2-ground
3-reverse interrupt
4-outisde +?
5-outside -?
6-temp sensor
7-temp sensors
oem
1-white-+12v ign
3-blk-ground
4-yellow-"cell"-
5-green-"ti s"-
6-brown-"hood"-
Thanks for the reply nilanium. I saw another post later, also stating that the auto lights would not work. This is a feature that I've been using for almost 10 years and would like to maintain.
My preferred option is to have my original unit repaired with the 'non leak gel' . But I'm in the UK. I understand some people have had their unit shipped internationally to this US company. So perhaps I'll contact them.
As this issue affects a few other makes - BMW M3 seems to come up often - I was hoping for a local company for the repair.
Gentex Mirror
Probesport,
Great job.!
How did you extract the large pivot ball from the gentex mirror.
I did figured out the donnelly,
But the Gentex, I just don't want to start yankin'and breakin'.
Thanks!!
Bill
Great job.!
Thanks!!
Bill
If the back of your Gentex has the extension with the ***** on each end, then you could do what I did. I cut the ball off the OEM window mount, cut the mount off the Gentex's ball nearest the gentex mount, tapped the ball, ran a bolt thru the oem mount thru to the ball, then jb welded it all tight. You still get the mirror-side ball for adjustment, the only difference being that this setup moves the mirror back a couple inches.
If yours has a different mount setup that won't work of course.
