Replace factory fender with newstyle fenders
Hi, Can I replace the fenders on my 2000 VDP with the fenders found on the newer ones. with the chrome. I have attached a picture. Id this possible? about how much do you think it would be. I could also just add the vents to my existing fenders.
thanks
http://autotraderca.files.wordpress....anden-plas.jpg
thanks
@ Moonman
I'm sure it could be done but would defenitely need some modifications, either minor (assuming the width is correct) you would still have to adjust where the fender joins to the body, and probably cut around the edges as the fender goes into the wheel arch.
Worst case if the width wasn't right you'd have to cut the fender in half and remove a section, then put it back together again.
Anything can be done but I guess a lot is up to how good you are yourself with fibreglass, or how much you are willing to pay someone who is.
Let us know if you try it, always good to see something new
RoyLittle0
05-25-2023 02:38 AM
KarimPA
09-03-2015 07:32 PM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
