replace steering wheel on an XJ8
Old 02-18-2019, 06:43 PM
SansuiMan's Avatar
Default replace steering wheel on an XJ8
how do I replace the steering wheel on an X308 99 XJ8?
Old 02-18-2019, 06:57 PM
King Charles's Avatar
Received 1,021 Likes on 741 Posts
Carnival Kid (02-18-2019)
Old 02-18-2019, 09:02 PM
aquifer's Avatar
When you get the new steering wheel installed, test drive it before you put the airbag back on. That way you can reset the steering wheel if you find that it’s off a spline or two. Set the old steering wheel as straight as possible before you take it off, so you can get the new one on straight. Chances are, you won’t hit it perfectly, thus my advice about test driving it before you put the airbag back on. You’ll get an airbag warning light, but it will go away after you hook it back up.
The following 2 users liked this post by aquifer:
Carnival Kid (02-19-2019), staffsbull (02-19-2019)
Old 02-19-2019, 09:55 AM
Also give your clock spring a shot of WD-40 or similar while you have it open, they tend to get noisy w/ age.
rosskuhns
02-24-2019 01:49 AM
Joe Enge
02-21-2019 10:27 AM
waynearny
02-14-2019 01:33 PM
sanchez
02-14-2019 07:49 AM
Quick Reply: replace steering wheel on an XJ8
