replace switch bulbs
Welcome to the board Steven.
Youtube is a belter for accessing these switches - you'll need to remove the shifter surround and ski slope (reverent sam a member on here posted how on youtube), then unscrew the switchpacks you need to access. Be careful with the connector blocks, and have the battery disconnected for safety instead of finding blown fuses...
Jaguar supply the bulbs, I went to the extreme of replacing every bulb with led's, all soldered so I never have that job to do again
Hi Sean, thanks for the info..........
I took out the ski slope the other day, then removed the screws holding in the radio and climate control unit..I then tried to pull both units from the dash. I gave up as they weren't for coming out easily.... is there something I'm not doing......or should they come out with ease ?
no, twist out's from the rear, did you find the top screw above all the switches, it's kind of hidden. It shouldn't be difficult once you've unscrewed them.
LED's are typically brighter than standard incandescent bulbs. Did replacing the bulbs with LED's make the switches too bright?
