Replace Third Brake Light Bulb in 2001 VDP?
SirJag (03-30-2011)
Hi
Here is a PDF file I created from JTIS CD. Shows how to remove and replace the bulbs in the rear high stop light.
To get the best viewing of the pages in this file, use Full Screen Mode option in the Window menu dropdown. While in Full Screen Mode, click any where on the screen and advance to the next page (there are 3 pages). Use the ESC key to return back to the normal display:
2001 XJ high stop lamp bulb R&R.pdf
It looks like an easy task to change the bulbs.
Jim Lombardi
Jim Lombardi
The following 2 users liked this post by jimlombardi:
hotelhiltn (04-09-2012),
SirJag (03-30-2011)
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
LED THIRD BRAKE LIGHT - JCWhitney
![](http://images.jcwstatic.com/jcwhitney/sku/images/small/I_123032_SW_1.jpg)
SirJag (03-30-2011)
Hi
Attachment 9060
Jim Lombardi
Attachment 9060
Jim Lombardi
![Icon Imnotworthy](https://www.jaguarforums.com/forum/images/smilies/icon_imnotworthy.gif)
<HANDSHAKE>
SirJag
I discarded that huge rattling annoying third brake light with this aftermarket LED light with no problems...
SirJag
BTW, the #168 is known to be good, the 5W5 is a newish cross reference number. The #168 also fit the side markers and possibly some of the interior lights, so you might want to get a box of ten.
Now, the #912 is 13 watts over the 5 watts of the #168. It has a bigger globe, but fits in the space no problem and has the correct base. Increased heat dissipation is not really a concern because they aren't lit for very long.
Before someone starts ranting about brighter brake lights ahead of them - that's the point, stay farther back.
BTW, about the LED thing ... if you've never seen the bulbs lit, then you still have to make sure the wiring up to the light works, so it won't solve that problem ... and then if you have tint it probably won't match the cutout.
Comes covered with a peel and stick. Took out the whole awkward Jaguar light, tapped into the wire that it was hooked up to and worked in both XJ8's without rattling, brighter light, cheap fix.
Tony K
03-26-2024 01:53 PM
Doberman_Fan
22
12-24-2019 06:21 AM
rudelover2
09-11-2015 08:53 PM
