Replaced front struts & top mounts/bushings : still cluncking noise
Old 01-08-2024, 07:27 PM
pdupler's Avatar
Received 1,110 Likes on 698 Posts
One more thing to check, very simple, there's a bracket to the center of the brake master cylinder attached to the firewall that appears to go from the firewall to the frame box section and the insulating bulkhead is attached to it. If those bolts come loose, it will make anything from an earthquake kind of slipping noise to a solid knocking noise that sounds like it coming from the front suspension in front of the driver when going over uneven pavement, particularly at low speeds depending how loose. Took me ages to track it down on mine as I kept going after suspension, engine mounts, etc. all the stuff you'd normally suspect. Not the easiest bolts to get a tool on to check, but the fix is free if that's what it is.
The following 3 users liked this post by pdupler:
BRG'83xj (01-08-2024), ForTheLoveOfCars (01-09-2024), Hooli (01-09-2024)
Old 01-08-2024, 08:59 PM
BRG'83xj's Avatar
That's a great tip. Ill have to check that out! Thank you.
Old 01-09-2024, 05:20 AM
Originally Posted by BRG'83xj
I seem to have the same issue as well. 2001 XJR 75k miles driver-side clunk at speeds under 30-ish, especially sharp, small bumps like uneven road surfaces and potholes. Basically, anything that is a sudden shock to the suspension, even if it's a small bump. I have inspected every suspension bushing, and while older, they are all in good shape and not ripped, the subframe front bushings look quite dry and rotted. I have new shocks and upper shock bushings, as well as new swaybar links and bushings. I have checked the ball joints for play, and they do not have any. The car handles normally, if a little vague, on turn-in. but I've never driven a new one, so I don't have anything compared to it and my last car was a little zippy hot hatch.
it seems to me its time to add the subframe mounts to the ordinary replacements list for cars this age if people leave the fuel filters to get as clogged as they due to location then those mount’s definitely need to be looked at the walking while steering i think is a clear indicator of this looks like ill be ordering some for myself i wonder if anyone has a part number to a good set for a good price but to be honest i feel the more expensive ones on this particular application might be worthwhile IMHO will be checking rockauto first i suppose not looking forward to this job especially as it gets colder out fml lol
Old 01-09-2024, 09:37 AM
RandyS's Avatar
Sub Frame mounts are only about $32 bucks plus shipping and could go a long way to
help eliminate some of your "clunks". ÜRO PARTS MJA2595AC
Old 01-09-2024, 08:58 PM
BRG'83xj's Avatar
Its looking like im just going to have to drop the subframe and do it all at once. I've been trying to troubleshoot it for months, and I can't, for the life of me, find which bushing or balljoint is causing it, so I will probably have to resort to the "it can't clunk if it's all-new" method. Just not looking forward to it
Old 06-09-2024, 11:51 PM
BRG'83xj's Avatar
Update: I have replaced the following and the drivers side clunk is still there.
  • Swaybar bushings and links
  • upper and lower control arm bushings
  • upper and lower ball joints
I have inspected the tie rods and the subframe bushings and they both appear good. There are no unusual movements during hard braking and accelerating, Cornering feels a little mushy and vague but again I came from a tight and stiff hot hatch so this is likely normal.
I am left with a couple of ideas:
  • The shock itself is bad and knocking. some online research of other Bilstien B4 shocks suggests that this can happen even to new or almost new shocks (mine are less than 10k miles)
  • upper shock mounts (also less than 10k miles) are knocking even with no visible signs.
  • Bad/loose engine mount
  • subframe bushing(s) are actually bad but not visually noticeable in place and at worse feel a little mushy (again might be normal based on my previous car being a sharp hot hatch)
Old 06-10-2024, 10:50 AM
RandyS's Avatar
Check to see how much play the shock has. Other members have reported
excess play after installation of new shocks.
  #28
Old 06-10-2024, 03:06 PM
hispeed42's Avatar
The hydraulic motor mounts can cause the same noises as the suspension when they are going bad and you might see a little puddle of liquid on the ground. When they get all the way too bad, they quit making noise.
Old 06-10-2024, 10:16 PM
Hell-Cat's Avatar
I can't recommend a set of these highly enough for tracking down noises like this: https://steelmantools.com/products/w...tic-device-kit
They aren't cheap but will save you a lot of effort and parts costs in the long run.
  #30
Old 06-14-2024, 04:45 AM
markdpeter's Avatar
I'd dearly love one of these but just can't justify the cost. Back in the day, they used to send small children up the chimneys over here. Maybe I could put a small child under the bonnet to pinpoint the squeaks and clunks.
  #31
Old 07-05-2024, 02:34 PM
BRG'83xj's Avatar
Alright, I have an update: I did the subframe bushings and while that made a huge difference in the front end's sharpness and has made the car feel much more stable, the clunk is still there! So i decided to put a gopro in the engine compartment and watch the shock mount, and it turns out that the NEW Meyle shock mounts are clunking! upon closer inspection, I even found that the other side (which doesn't make noise...at least that I can notice) has its rubber splitting apart now ( it wasn't last I checked maybe a month ago ). I have some new ones on order and hopefully, this will finally fix it. What is so weird is that it looked fine and felt perfect in every situation but driving it. I could jump on the car, wiggle the shock, etc and it wouldn't make a peep but on video, its clear the bushing is far too soft which allows the two parts of the bushing to touch on sharp bumps.
Edit: Upon ordering the new parts I noticed that the bushing from new on the Meyle part should be a white/grey color and mine are yellow kind of like the URO parts ones. Maybe there are/were some knockoff ones circulating or something because its clear that these parts failed in less than 2500 miles from new.
I can also post the video if anyone is interested
  #32
Old 07-05-2024, 04:04 PM
RandyS's Avatar
You have a lot more patience than many I know. I certainly hope that fixes it.
I kind of thought that might be what it was.
  #33
Old 07-05-2024, 04:06 PM
BRG'83xj's Avatar
Haha thanks! met too
04xtype04
05-12-2014 02:06 AM
Spinedoc2304
02-08-2014 01:45 PM
yeeran
11-06-2012 03:16 AM
p-Rock
07-27-2012 06:00 PM
KRK_Jag
07-12-2012 10:45 PM
Quick Reply: Replaced front struts & top mounts/bushings : still cluncking noise
