Replaced Rear Wheel Bearings
Just replaced the rear wheel bearings on my 00' XJR. The car had developed a "roaring" noise in the rear, so I decided to take a look. I found that the driver side wheel had a excessive play vertically, but just a little horizontally.
The outer bearing was shot and full of metal debris/shaving. It appears that the seal failed at some point and allowed junk to enter the bearing.
The job itself was not difficult, but you'll need access to a press and a set of bearing hub tools.
I did manage to break the abs ring during the install and had to order another one, but very pleased with the overall results.
If anyone needs help give me a shout.
BrentGardner
28
04-26-2024 03:08 AM
Doberman_Fan
22
12-24-2019 06:21 AM
Fraser Mitchell
10-01-2015 04:06 AM
