Replacement Key and Remote
Old 02-18-2008 | 10:48 AM
Serbian Highlander's Avatar
Default Replacement Key and Remote
Any ideas on the best place to go to buy an additional key and remote? Just bought the car and it only came with one key and remote.
Old 02-18-2008 | 12:01 PM
jag_genius's Avatar
Default RE: Replacement Key and Remote
the dealer.. key has to be cut and programmed by a dealer.. remotes can be programmed by you.
Old 02-18-2008 | 08:10 PM
FactoryJaguarTech's Avatar
Ahh but if you are paying for the key to be programmed....the remote programming should be included. I would go that route just in case something wrong with remote you buy. Tech can fix right away, you cannot.
Old 02-18-2008 | 08:17 PM
dougs02's Avatar
You were there first jag_genius, but FJT nailed it. LOL
Doug
Old 02-19-2008 | 07:28 PM
jag_genius's Avatar
just stating facts of the vehicle
Old 02-19-2008 | 10:08 PM
LOL.....very diplomatic and factual response. Nice to find someone with some integrity!!
Old 02-19-2008 | 11:30 PM
Thanks for all of the good advice. I talked to a dealer here in Illinois today and they can get it done for about $275 -- key cut and remote.
I have read stories how you can get a replacement key and it will not work. I take it that the key has something buried inside the key behind the jag emblem or in the key shaft. Is this true, because if so, i will need to test it out at the dealer before leaving.
Thanks again.
Old 02-20-2008 | 07:20 AM
Yes Serb the 2001 XJ has a key transponder module in the car, also the key, if you look at the very end, you will see a little rough spot - that is the transponder, basically a chip. That is why it needs to be programmed. If you have two working keys, you can programme the keys yourself, if not, you have to pay dealer to do it. Again, make sure you have all keys and remotes when you go to the dealer so they can make sure they programme everything at the same time and also that everything works when done.
Old 03-04-2008 | 08:36 AM
xke1963's Avatar
I have two working keys and the valet key but needed a third one. I had the dealer cut a new key. How do I program it? Thanks in advance as the dealer is not real close or convenient
Old 03-04-2008 | 07:30 PM
Sent you the email, do you think you could copy and paste it here for everyones benefit?
jjd247247 (02-14-2015)
Old 03-05-2008 | 09:25 AM
xke1963's Avatar
Thanks for the help. It worked fine and took less than a few minutes. Here is the e-mail instructions sent by FactoryJaguarTech:
Start the car with known good key, shut off and remove as soon as it starts, put in next known good key and repeat followed by other two keys. 1,2,3,4. All keys should then start vehicle. "
The following 2 users liked this post by xke1963:
JagChic (05-26-2022), jjd247247 (02-15-2015)
Old 03-07-2008 | 01:28 AM
tucats's Avatar
[align=left]So it has to absolutely begin with two known keys? I just bought a (beautiful!!) 2000 XJR but the dealer only had one key and remote. He was able to get two new keys from Jaguar for me (remotes are on the way from another source) but obviously the keys need to be programmed.
When I called the Jag dealer they wanted $513.00 for one key and remote, plus the cutting, programming, etc. Is there any other way to accomplish this with one known key?
Also, is there any way for me to learn what the service history on this car is?
Thanks in adance!
[/align]
Old 03-07-2008 | 08:03 AM
xke1963's Avatar
Programing method worked just fine. Here is the e-mail that I received:
Hope this helps.
Old 03-07-2008 | 08:13 AM
xke1963's Avatar
Not sure about programing with one key. The remotes are easy and can be done even if you don't have any to start with. There are two styles for the XK8/R. Make sure you get the earlier one with the squared shoulders. I bought one on EBAY for $25.00. Put new batteries and programed it. Basically, open the door, hold the high beam flasher in flash mode and while still holding it, insert key and turn to position 1. Then flash about 4 or 5 times until you hear a chirp. Then push any button on the remote and go to the next remote and do the same.
The list price for a key is $80.00 which includes cutting. It is that much as it is the chipped style. From what I have heard, the dealer charges 1/2 hour to program a key which should be around $50.00 depending on your area.
Old 03-07-2008 | 09:17 PM
The $500+ is a little steep. LOL. The cut for the key should be about $3.00 The Key anywhere from $40-90 and programming 0.5 hours.
Programming keys without the computer absolutley has to have two programmed keys.
Old 03-08-2008 | 12:46 AM
tucats's Avatar
Ok fellas... thanks for the responses! Looks like it's time to suck it up and head for the dealer. Was really hoping to avoid that....
Old 07-22-2012 | 09:49 AM
louisgar's Avatar
Default remote xj8
try ebay, i bought one there and after they sent me the invoice i realised
that i bought the wrong one. i have the 03 to 06 model . it has an uncut key and the control together.
Old 07-22-2012 | 10:00 AM
louisgar's Avatar
Default 98 XJ8 remote programing
Does someone know how to program the keyless entry remote. I bought the car with just the key. And now the cylinder to open the door is not working any more. So I found a control on e-bay and am trying to program it to my car.
they say it's not to complicated.
they say you must open door, turn key from off to the first step turning key four times back and forth fairly quick. and will hear a chime at the 4th turn.
turn key to off . take key out close door and control should be working.
I tried doing the 4 off on and am not hearing a chime.
can some one help?
Old 06-14-2014 | 11:54 AM
kll618's Avatar
Default ebay Jaguar Keys
Hi, just got a 2005 Jaguar XJ8 3.5.
it came only with one key, i saw a few uncut keys on Ebay, also instructions on how to program the FOB on the web.
Question is, i hear the key also has a transponder, is this programmable?
thanks
Old 06-14-2014 | 01:32 PM
bigcat777's Avatar
Keys can be cut and programed by any locksmith with the proper machine and 1/3 the cost of the dealer. Had my keys (2) cut and programed for $120.00 total. You can find keys online too. The fobs need the programing listed on this post. Just saying.
Quick Reply: Replacement Key and Remote
