Replacement Key and Remote
I bought a blank Tibbe key from a company called triple C on the internet. The problem was having someone program the key. I could not find anyone in Houston to program the key. I happened to have an extra key and sent that key and the blank key to a locksmith in Kansas City called Brandt Locksmiths. If you only have one key, this may not be a good option. Maybe the Jaguar dealer can still do it, but they charge an arm and a leg. As for the remote, they are usually available on eBay. I bought a couple extras. You have to program all of the remotes at once. The instructions are available on prior post and on the internet.
No, not really. Anyone can reprogram the remotes with simple instructions all over the internet. They key youll need cut and coded, but no way the dealer is your only option. Tons of automotive locksmiths can do it for you at a fraction of the dealer cost. I cant stand all these "gotta go to the dealer" black and white answers, no offense to anyone. Use the internet, its your friend. The dealer isnt
I live in a large city (Houston) and called a bunch of automotive locksmith's and couldn't find one who could program the key, so this may be a problem in the future with these old cars. As I wrote in my original post, I had to send one of my keys to a locksmith in Kansas City in order to do this.
You don't NEED to go to the Dealership
Gunked up fob buttons. Pull the fob apart, take a paper towel and some rubbing alcohol and clean the stuff off the pads and PCB contacts. Don't be afraid to scrub hard, mine didn't work and it took a couple times cleaning, second time cleaning the rubber pads a bit stronger than I thought they needed. Worked fine since.
Key duplicates in Los Angeles area
Just had a duplicate key made and programmed for my 2003 XK8 at Lock Solutions on Burbank Blvd in North Hollywood. Total price $125 and works perfectly. Far less expensive than the 4-500 dollars charged by LA area Jaguar dealers and some other locksmiths. (They may be able to come to you for an additional cost as they seem to have all the equipment required in several mobile units.) I did not need a remote FOB but they handle those as well. (But as noted in other posts, if you can find the right FOB - with same ID numbers as others you have - they're easy to program yourself.) Car needs to be with you at the time of key duplication. Also bring any other keys you may have for the vehicle as the programming for the new key will then replace the programming for the others but they will all work fine. No extra charge for those additional programming changes. Small shop, very nice people to work with, took about an hour. Call first to make sure they have your specific key in stock. Apparently Ford is now going to the tibbe type key on some vehicles, so there are sources for the uncut keys besides Jaguar itself.
#31
Sorry, but I was told by the Jag dealership that obtained my blank and cut the key per my VIN # (I lost my only key ) - @ $120.00 - that only a Jag dealer can program things so the key works with the car. I trust them, b/c it turned out the guy that cut my key is also a former client and friend. He would not lie to me on that point. The dealerships have a specific Jag machine for that sole purpose (I forgot the acronym for it).
#33
tmurray
03-31-2015 11:38 AM
princessoftx
16
06-29-2007 04:25 AM
cutting, jaguar, key, keys, programming, remote, replace, replacement, spare, transponder, type, xj, xj40, xj8, xk8
