Replacement lower ball joints
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Hi everyone.
Following a recent visit to my local Jaguar Dealership, it was noted that my lower ball joint on my XJ8 Sovereign LWB ('98) have slight play, and I was advised to have these replaced.
I was quoted 531.00 GBP but have seen the ball joints advertised for around 20.00 gbp each.
Rather than pay the ridiculous labour rates at my Jag Dealer, I was wondering if anyone has replaced these on their Jag, and if you have a step by step procedure so I can pass this onto my local friendly garage who haven't touched a ball joint on our type of vehicels before.
Also, does anyone know if a spring compressor is required for this job, and what are the torque settings to apply?
Thanks in advance!
Thanks in advance!
Just replaced the upper and lower ball joints on my 98 VDP with 168,000 mi. The lower ball joints were shot with a lot of play. I first tried to use a ball joint separator that looked like big clothes pin .... don't waste your money. Also, a pickle fork is worthless for this job.
What works is the large C-clamp with the various pipe tubes. I used one that had an opening of about 14" to 16" and a drive screw that was an inch in diameter. With the torque that was applied to press out the ball joints I am not sure if a c-clamp with a drive screw less than 1/2 inch will hold up.
al_roethlisberger
09-11-2015 10:04 PM
KarimPA
09-03-2015 07:32 PM
