replacing abs module; do numbers need to match? help please
Hi. I have a 99 xjr and a 99 xk8. I am getting code 1095 which is the abs module. Just to confirm this, i wanted to remove my module from the xk8 and put it on the xjr to make sure the problem goes away. I did notice the numbering on the module, and my two modules have different numbers. Do the numbers need to match or will any module of that year work. Thanks for the help.
There are 5 modules for the X308/X100 cars depending on the MY and IF the car has traction control.
JLM20555
JLM20556
JLM20129
JLM20130
JLM21323
If you have 5 pipes (6 valves) on one car and 6 pipes (9 valves) on the other valve block then the modules WILL NOT INTERCHANGE!!!!!!!!!!!!!!!!!!!!!!!!!
If your XK has a VIN 018108 and later, then the JLM20555 (except traction control) or JLM20556 (traction control) are the same as the XJ sedans with or without.
Sounds like one has one has 5 pipes and the other has 6.
You need to call the Jaguar parts dept with each VIN and ask for both part numbers to see if they are compatible.
You will probably find that the XJR has a JLM20556 and the XK8 has a JLM20555.
Good luck
bob gauff
P.S. I just repaired another JLM21323 module because I sold one last week to another shop that did NOT want to cut open the pricey module and risk damage.
It's not hard if you go slowly and cut carefully.
JLM20555
JLM20556
JLM20129
JLM20130
JLM21323
Good luck
bob gauff
If the module has NO cracked solder joints and the C1095 faults persists, then the fault might actually be the PUMP MOTOR!!!!!!!!!!!!!!!!!!!!!
Did you apply 12 volts to the pump motor to verify it's operation??????
Do some diagnosis and report back before condemning the module.
It's rare but the pumps can fail.
bob gauff
bob gauff
RJ237 (07-28-2012)
Bob,
New to the forum and new 2001 VDP owner. Just got the TRAC OFF/ABS unavailable error - dealer says don't worry until complete failure then cough up $3000. Have follwed some of your post. In looking ahead to possible replacement of module; do you have any experience with Internet retailer "Module Master" who states they will rebuild the ate/teves mark 20 module for approx $100 plus shipping. Thank you in advance.
Mike
Mike
mdtopless67 (07-31-2012)
mdtopless67 (08-01-2012)
