Replacing the Bumps Stops on my xjr with smaller ones
Hi Ladies and Gents, I want to replace the Bumps Stops on my 2003 XJR with smaller ones. I have a 2003 Jaguar XJR R1 with 8 x 18 ET33 BBS Milan Wheels. I recently Purchased 9 x 18 ET35 BBS Milan Wheels. The 275/40ZR18 rubbed on the Rear Bump Stop MNA3750AB. I was advised to replace the bump stops with the Bump Stop from an earlier model XJ40 XJ6. Here is the part # MNA3750BA. As anyone on the forum do ne this ? If so, is it a straight forward bolt on ? Or does it requires modification ? What do you think ?
I just used an angle grinder with a thin cutting wheel (lacking a lint saw), and cut off the protruding steel part, along the edge of the rubber.
It is a bit of a mess, as the rubber is vulcanized on the steel frame, and there is no way not to cut in it ( a lint saw will do much better there).
Quick and easy job though.
ericjansen (10-03-2018)
TenPercenter
17
11-08-2023 04:16 PM
caferacer
03-24-2017 07:16 AM
jsupstarz
11-27-2012 08:36 AM
WaterDragon
10-08-2012 12:54 AM
