Replacing fuel pump but from inside
Old 07-28-2024, 02:36 PM
Vauxi's Avatar
Originally Posted by Quadcammer
I don't agree with his post either, but have you tested your secondary fuel pump to see if its working? that seems to be a common failure for the supercharged cars as it only runs sporadically.
Why you mentioned to test my pumps. Secondary pump is dead. Primary works fine. Since the car works as always. I will not do anything in this summer.
Old 07-29-2024, 03:26 AM
Hooli's Avatar
Originally Posted by Vauxi
No other way than full throttle. EU gasoline is way more "better" than yours. It will go bad too but not that fast. I might jump the relay on in someday to test the pumps.
Pull the relay in the boot & bridge the contacts, then you'll hear the secondary pump running in the tank if it works.
As for fuel, I believe it's pretty much the same quality, just the US uses a different measuring system so the octane numbers are lower. MON not RON, I think.
Old 07-29-2024, 03:27 AM
Hooli's Avatar
Don't floor the throttle too much then, it'll be running lean at high throttle with only one pump working. From memory the second pump comes in at near full throttle or over 4k rpm.
Old 07-29-2024, 05:17 AM
Silverjag0's Avatar
Originally Posted by 64etype
I used that photo in a Jag-Lovers forum post regarding "out the top" removal technique. I cut it out with abrasive wheels. No way would I remove the tank. I covered the top of tank to avoid sparks directly on the tank and hoses....It's discussed in the link.
2002 XJR no start - X300 - Jag-lovers Forums
Brilliant work
Old 07-29-2024, 05:22 AM
Silverjag0's Avatar
Originally Posted by Highhorse
So, the posted pic, is that yours or just one you borrowed to show your intentions? Because that one wholeheartedly appears to have been die ground, ..clean cuts. I don't see any warpage or fraying from the use of snips.
Your prowess to not permit you to go that route is saying your going to pull the tank into the boot?
The picture is from x300 froum iirc
It looks like it need more experience to cut that I'm not experienced with cutting I asked my mechanic to do the job but unfortunately he's out of the Town for while the cat will be at sleep sweet my jag
Old 07-29-2024, 12:45 PM
Vauxi's Avatar
I did that. Secondary does not spin at all. I've heard that atleast Finnish gasoline should be great quality. But I don't know for sure. Since I just aquired working VCM1. I can now see short term and long term trims during wot.
Hooli (07-30-2024)
Old 07-29-2024, 05:57 PM
64etype's Avatar
It's easy to cut out the opening with a Dremel, although I would use a plug-in version or an air powered cut-off tool versus a battery powered tool (I used both).
By the way, the first post in the current thread linked below mentions fuel pumps replaced at 36,000 miles. Hellooo! There are many such references. Yes, Jaguar purchased pumps from vendors, but Jaguar failed at setting the required quality/longevity standards and requiring test data that proved the off-the-shelf parts were up to the task. Mine actually failed at 38,000 miles, not 40,000. PS: There are no structural issues with a hole the size of the one depicted in the first post of this string.
'99 XJR Value? - Jaguar Forums - Jaguar Enthusiasts Forum
Silverjag0 (07-29-2024)
  #28
Old 07-30-2024, 08:48 AM
RandyS's Avatar
My guess is that anything that was outside the warranty period was
ok with them.
98Jagxjr
07-06-2024 05:24 PM
Josh Nichol
04-29-2024 01:36 PM
plums
General Tech Help
01-17-2016 02:28 AM
Paulc732
05-27-2015 11:32 AM
Quick Reply: Replacing fuel pump but from inside
