Replacing instrument cluster
The 4.0 engine cars (X100/X308) can use a replacement INSTPK without any configuration.(VCATS part number and suffix match is recommended)
The ODO will follow the INSTPK, not the car.
The 4.2 engine cars have a VID block and that is where things get complicated!!!!!!!!!!
I took out the instrument panel to try to fix the speaker problem hoping that it was just a bad solder joint but after soldering its it’s still silent
I have another 06 s type for a parts car but it’s not an STR and I was going to replace the instrument panel with the one from the non str parts car but due to the fact the instrument panel is a major gateway between several of the buses and all of the modules I was hesitant to do so.
once I figure out what the ramifications are swapping in this used instrument panel from a non-STR I may give it a try.
Any suggestions?
car5car
10-16-2023 11:42 AM
LoopbackZero
08-29-2014 12:58 AM
