Replacing my rear shocks
Car: 1998 Jaguar XJR
I'm currently in the process of replacing my rear shocks and cannot for the life of me get my springs compressed far enough to get my shock/spring assembly removed from the car. I've read over the couple of write ups I've seen about the process but I am still stuck. I was hoping someone on here has had a similar problem and could give me some tips on removing them. Any help would be appreciated. Any recommended spring compressors I should be using? I'm willing to buy any tools I need...
BigTexx (04-15-2014)
The following 2 users liked this post by Probesport:
BigTexx (04-15-2014),
Catenaccio (04-23-2014)
Since I just did mine last weekend I will add some of my procedures.
1) jack and support vehicle
2) Remove rear wheels
3) Remove rear callipers (this makes removing spring much easier)
4) Remove 4 bolts under diff that are in a square pattern
5) Pry down the plate under the diff and put a wedge in there - I used a 36mm socket, you wont need to keep prying or bending as you just need a couple inches of clearance.
6) Unbolt shock, 4 nuts on top, one bolt on bottom
7) Remove shock and spring as an assembly
Installation is reverse of removal
Fraser Mitchell
10-01-2015 04:06 AM
Doug Dooren
08-30-2015 08:51 AM
