Replacing seat belt buckles, seeking input.
Received 1,803 Likes
I would ask Dave, he always seems to have items such as this or know where to find them... https://shop.everydayxj.com/XJ8_XJR_...003_s/1841.htm
This is site that has a lot of items you never know what you'll find... XJ8-VDP-XJR (98-03) - Body Parts - Page 1 - Jaguar Parts Specialist
Not exactly sure what a Seat Belt Cap is, but here's some more to look at... https://www.welshent.com/Interior-Fi...2789&ps=24&p=1
Oh, well then...I read that wrong...
....for the rear, definitely and if I were home I'd be able to go to the garage and tell you almost assuredly yes for the fronts. They're both fairly easy, its just the fronts are a bit heavy with all the electronics. All you should have to do is remove the electrical connections, undo the 4 anchor bolts, move the seat back all the way, lean the top of the seat forward and using the rear rails as a pivot, lift it into the back seat area to access the seat belt anchors.
![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
