Is replacing the supercharger an easy DIY Job?
I have seen a nice looking XJR locally that the seller is saying needs a new S/C.
How easy is it to replace the s/c, is it a DIY job?
How would you determine if it truly was the S/C that has gone T/U?
What other damage could the S/C going south cause?
Here's a link to the car.... http://austin.craigslist.org/ctd/1303644677.html
Does this look like a reasonable price, or is a pile of junk? What would it need apart from the S/C, would it likely need timing tensioners, water pump, gearbox work etc?
Thanks in advance..
- Tim
Thanks in advance..
- Tim
I think John's right about the price of an unbusted example, and would also add this:
Smilin' Jimmy has him a $9,000.00 Jaguar to sell, but the dern thing won't run right. If Smilin' Jimmy, or Clem out in the shop, has accurately diagnosed the fault with this car...they slap a good used blower on 'er for a few hundred bucks and roll her back in line. Jimmy's not Smilin' when he leaves a few grand on the table by dumping a car cheap that he knows how to fix.
So my first assumption would be that this car has a much larger problem than a supercharger fault. Maybe Jimmy and Clem are honest good ol' boys, they don't know too much about Jagwires, and they cypher that it must be a supercharger making all that fuss.
Or it has a broken timing chain, or a rod knock, and someone is going to be really disappointed at how much they paid for a $2500.00 car.
Jimmy's Smilin' anyway, 'cause that's all he paid for it at the auction when it was pushed through the line. So he's making a living, whether it's an honest one or not. Clem's happy, 'cause he sold the console lid and the CD changer on Ebay when Jimmy was at the auction looking for more diamonds in the rough. And the pulleys of commerce keep on a turnin'.
I'm think I've bought a car from that Smilin' Jimmy guy. That his rep has made it all the way to Ohio is a pretty bad sign.
Tim - Easy solution is to contact the guy and get the VIN and check it out. If it seems ok on paper history, head to Lockhart and get some BBQ for lunch. Then go take it for a drive. If you have a code reader, try and pull codes. Take it to a shop and have them inspect it, compression test, leakdown, etc. Check the intake for excessive oil in the air filter or MAFS. From first hand experience, you should not buy that car without all of the above. That one even looks exactly like mine. If it turns out to be only the s/c, it will run $750-$1,000 for a rebuilt unit, so add that to your $6,500 OBO and you are at or below market value. But as far as Smilin' Jimmy knows, you'll need a new unit for $2,500. Be sure to have more BBQ for dinner as you leave Lockhart, at a different BBQ joint.
Thanks Markus,
There's probably more than a shred of beefy truth in my little story, but I had a whole kettle of fun writing it. Glad it suited your appetite.
Tex, you've given me a new item to for my pre-purchase inspection list. Right after
"Inspect front suspension for worn components/ free play", I'll now have to add "Check BBQ joints".
Maybe I can even sneak out of one of them with a steak knife in my pocket. Then I can cut off the supercharger belt, and we'll see what all the fuss is about.
JTO - I trust that you will post your revised checklist with the appropriate BBQ joint requirements. Beef, chicken, pork, turkey? Check. Green vegetables of any kind, except marinated or pickled peppers? no? Check. Secret recipe homemade BBQ sauce? Check. Really fat guy cutting brisket? Check. Really fat guy's hot college-aged daughter manning the register? Check. Lockhart Texas is a BBQ lover's paradise. Curiously, there are relatively few skinny people there. Which brings us back to the importance of "Inspect front suspension for worn components/free play."
It's really fun to throw something out in the wind and see who catches it. Nice to know ther's a helluva center fielder out there. Good arm, too.
I'm off to the local Skyline Chilli franchise...that's our local slophouse for immitation fine cheap victuals. Got my floorjack and a few spare lower wishbone bushings wit me to sell to the really good customers. Bon appetite!
Although it might be a gem, it might also be a dog. I've always wanted an XJR, but I'll keep the XJ8 (X350) for a few more years and then start looking for an 05 or later XJR (X350). By then then will be worth very little and IMHO the 04+ XJ8 is the best of the bunch....
- Tim
- Tim
Well, 04+ may be a good runner, but the car started a style regression after 03.....raising the roof, moving the gas filler....I dunno, but I like the 03. I hope the new one grows on me. I have had a jaguar since 84, more than one most of the time....but that new one will take some time to learn to appreciate.
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
