Restricted Performance After adding coolant
I had to add about 1/2 gal of engine coolant to my 2001 Vanden Plas 4.0 non-SC. Ran engine with heater on, temp gauge got to mid range. I let it cool and opened expansion tank. Looked good. Got in car, and whammo, there is the Restricted Performance (amber). Anybody got an idea what happened? And, can I drive it. The manual says yes - to a Jag dealer!
Restricted Perf. Adding coolant
Thanks Guys, I don't get codes. I did spill some coolant when I opened the thermostat housing cap. I was told to do that at same time as opening the expansion tank cap, since my "car expert" friends suggested I had an air block from changing out the coolant previously. Didn't do anything else that could cause the restricted warning, that I know of. This happened yesterday, and today I still get the warning message after turning the key on/off about 5 times. May have to take it to the shop. All this started as a way to avoid changing the thermostat, which again my friends suggested was my original problem.
If you have an amber/red light on, there will be a code, or a number of codes stored within the memory of the car, pointing a technician towards locating the fault.
What is also a concern, is coolant (and it only needs to be a thimble full) dripping into one or maybe several spark plug holes. These are located under the reservoir, under a cover. If you'd like to check, undo the 8? bolts, remove the cover, and remove the ignition coils. They have rubber boots connecting them to the plugs. Moisture in, around and about will certainly "throw codes"......I hope this shines a light on what above posters are telling you.
Johnken
09-15-2015 05:46 PM
