Restricted performance issues!
![Cool](https://www.jaguarforums.com/forum/images/icons/icon6.gif)
This is a little strange to me. The restricted performance comes on "every other time" i start the car and stays on until i cut the car OFF. If i re-start the engine right after cutting it off, the restricted performance goes away. The car runs normally (perky Jag!).
What do you all think this may be? While at the Jag dealer, a little time ago, even thy did not diagnose it properly (they said they may have to smoke it to try and chase down a leak. A different Jag Mechie says it may just be the purge valve. How can that be, if you can just turn it off and on again and it runs OK?
Any thoughts fellow Jags?
Maybe time to invest in a cheap OBD reader and plug it in, or go to Autozone and have them plug it in while the restricted mode is active...the port is under the steering wheel next to the trans tunnel. I use a memoscan OBD reader for quick diagnosis.
Basically the code will point to the fault and then we can suggest a fix.
Otherwise is guesswork.
Aus V8S
11-13-2015 11:01 AM
scottatl
09-04-2015 08:08 PM
