restricted performance light simple cure
Guest
Posts: n/a
I have a 2000 xj8 with about 63000 miles on it that I bought a year ago. It has been troublefree except for a restricted performance light that has been intermittent for the past 6 months, getting more persistent the past month.
It was caused by a dirty air filter. New Frams are a little over 9 bucks at rockauto.com
Guest
Posts: n/a
RE: restricted performance light simple cure
I don't have the equipment to check the codes. It's easy to check if this is the source of the problem; just unbuckle the air cleaner fasteners so that there is a little opening between the two parts of the housing and start the car. Obviously, you don't want to do this in a dust storm! I live in the Pacific NW, so clean air is in abundance.
Ihave driven it several timesand not a sign of the dreaded light, The check engine light has even reset itself, so I'm a happy motorist.
As someone whose first mechanical projects were repacing the centerbolt in the rear spring and rebuilding the carburetor on a 47 Ford Deluxe, I learned to try to diagnose and repair as simply as possible. It doesn't always work, but it doesn't cost much to try.
02jagstype
09-04-2015 08:20 PM
03, 2000, displayed, jag, jaguar, jaguars, light, lights, message, performance, perfromance, restricted, ristricted, xf, xj8
