Restricted Performance light on when stopping
The P1474 doesn't show up in the XJ chart but does in the S and X ones as the mentioned left upstream O2 sensor heater.
The stopping association keeps saying brake switch to me but let me go further out on a limb . . . how old is your battery? Dropping to idle and lighting the brake lights may drop the voltage just enough to trigger the heater code. It draws about 6a cold but that should less when warm. These Jaguars do strange things when you don't give them enough voltage.
A quick free charging/battery system check at your friendly local auto parts store might be a place to start.
