restricted performance message on 2000xj8-L
Guest
Posts: n/a
Hello, I recently took my 2000 xj8l out of storage. After i let it warm up for about ten minutes,I went outside to find a pool of antifreeze under the car. I didn't touch it again until i drove it the 1/2 mile to my mechanic to get it looked at. He found that a house had come loose and fixed it for $65.Now i have A restricted performance message.Car runs better than it ever has; Quiet, responsive, smooth.Then I hit 3,000 rpm and bang against what feels like a rev limiter.I seriously doubt anything is wrong with my car besides the (code ? ), but I'm leery of taking it to the dealer. Especially because they charged me $850 for a battery and a fan belt. Which didn't help any due to the fact that the alternator was the problem. Can anyone help?
You need to get the codes checked. It could be any number of things, and if the Restricted Performance light is accompanied by the yellow light, it's likely small and the car is still driveable per the owner's manual. If it's the red light, you need it checked immediately. Why don't you just have your mechanic check the codes? Or, for $50 you can go buy a code reader and check it yourself, and we can help diagnose it.
JTO, when the RP comes on, it limits it to 3,000 RPMs. The limiter is actually a pretty abrupt, violent shake, because it doesn't cut for a long enough time like most limiters will, which means you bounce against it a couple times in an extremely shot period of time. Freaked the hell out of me when it happened. In my case, I was getting a P0174, and a new MAF cleared it up.
Guest
Posts: n/a
Thanks guys, the light is yellow and i drove the car today,restricted performance message went off and the rev limiter disappeared, but the yellow engine stayed on.I will buy a code reader and pull the codes . Looked around at other posts before posting thi and saw a lot of MAF problems, but couldn,t find the part online. any suggestions? Thanks
Premature until you read the codes. Part of the alarm in my first post was the radiator hose incident, as this is often the result and not the cause of overheating. A sticking thermostat or failed water pump impeller will cause the engine to run hotter than the dash gauge sometimes indicates. That's one way bad stuff starts to happen, and the hose blowing off the thermostat housing is possibly a clue, not always an answer.
Cleaning an MAF that is initiating codes and causing acceleration problems will often be sufficient. Recurring problems will require a replacement: new ones are readily available, but I wouldn't sell (or buy) a used one without a full guarantee... too much of a gamble, and at this point only a guess.
Sky, when I had my problem, it was intermittent as well. The yellow CEL stayed on, but the RP would come and go. Chances are, it will be back. Still get the codes checked anyway.
JTO, wish I hadn't experienced that extreme pleasure either. For me it would all be running smooth, and would usually come on without warning as I would be trying to pass someone or go up an incline. Suddenly get the RP message out of nowhere and the rev limiter would kick in. Not fun at all.
Nick, depends on what you want. You could get a $50 reader at your local parts store if you just want the code numbers, and you can get $3-400 readers that can give you real time data and monitor different systems while you're driving, etc. For most things, the cheapy models are sufficient. For more advanced work, more advanced readers are helpful. You can go to your local auto parts store and look at some different models, then shop around online for the model you like at the best price. There's no "one size fits all" answer.
X308XJR
05-20-2019 06:50 PM
Collector1
09-28-2015 03:52 AM
