restricted performance and won't rev above 3k
hi guys I changed the fuel pump after 5 hours of working on it my god the lines under the car is nightmare if you doing it for first time any way after changing the pump the car work but still show restricted performance and won't rev above 3k rpm I connected obd rearder and found these codes p0102 mass or volume air circuit low- p0122 intake air temperature sensor 1 circuit low - p0333 Knock sensor 2 circuit high Bank
I have read different threads about the knock sensor problem I think my car have faculty knock sensor what should I do ? change both of it? or it's fixable?
where should I start to fix .
in case my signature is not showing may car is 2002 xj8
thank you.
thank you.
I agree on the knock sensor.... when mine went, it sucked when the restricted performance came on for it and she chugged hard each time I tried to apply descent pedal.
For replacement instruction, this link from Jim Lombardi is priceless.... https://www.dropbox.com/s/ti0842gz36...Y%20N.pdf?dl=0
The original thread for it is here, you'll note the alternate sensors used instead of the expensive X308 ones. I wound up using knock sensors for a 2005 4.2L, which is said for a XJ8, mine is an XJR and its been over a year with no issues.
the car still run fine below 2800rpm and shifts normal.
I will check how much is that 2005 4.2l Knock sensor because the knock sensor for my car cost 133$ in rockauto.
thanks ray for the link I checked the sensor in auroparts warehouse it's not 27$ I think that might be old price maybe?
do you think 2002 Lincoln LS knock sensor will fit into my car ? maybe with some connector modification?
Yeah, check the dates of those posts, you have to search because deals come and go. Even the ones I got from NAPA just a year ago aren't even showing up on their website (got them for $67 ea). The pricing CK is showing are pretty good, usually the cost is around $125+ ea.
No one can say what may or may not fail...as far as replacement, mine were almost necessary I replaced both since I have to pull my SC to get to them. For yours, they are readily accessible and if you only need to replace one, that is your choice. You may wish to buy both and replace one,...again, your choice. My attitude is, your there, why not do both....don't let it lapse that these are 17-23 yr old cars, parts will need replacement.
As for the Lincoln sensor...I do not know...perhaps someone with knowledge of that fitment will chime in?
I think there's some engine parts from 2002 Lincoln LS and 2002 ford thunderbird that can fit into x308 jaguar
Sarahtonin
01-04-2018 01:15 PM
OldKingCole
XJ40 ( XJ81 )
10-29-2014 06:06 AM
jukes4me
12-18-2013 11:10 PM
giandanielxk8
01-06-2013 04:06 PM
