Reverse (backup) parking sensor odd problem
Hi All,
I've got an odd problem I wondered if anyone else had ever experienced.
My parking sensors will intermittently (once maybe twice a minute) stop beeping for a few seconds (different number of seconds each time) and then start working.
Tests done so far:
1. All sensors are clean and clicking as normal.
2. All sensors will respond to objects getting closer when I do a manual walk round the back with a magazine test.
3. All sensors are plugged in properly.
But at the moment, the car is maybe a yard away from my garage wall and should be slowly beeping all the time except it keeps stopping.
Do you think this is a sign of a bad module? If so, if I was to get another one of the same exact numbers will it plug and play or does it have to be recoded to the car?
Yours,
Joe
Tests done so far:
Yours,
Joe
Joe - no any module will do but I suspect parts guys would want to sell the complete kit. It's worth asking the usual Jaguar breakers, but my guess would be eBay, that's where I sold the last one. Have you thought about the speaker? I know the X types failed alarmingly.
It's located on the parcel shelf under the trim, a bit of a git to access, you need to remove the seats, which might look hard but it's a matter of a few screws and bolts.
Hope this helps
Hope this helps
joebongo (06-12-2013)
Oh **** - my reply didn't post yesterday.
Thanks for the info Sean. It's good to know it's a plug and play component - the one in the BMW 7 series had to be programmed in and was a right pain to match up.
Having slept on it, if all my sensors are ticking away and they all respond as normal I think it must be the module unless anyone can think of anything else that would cause very intermittent failures/pauses like this.
The speaker sound is all normal - never crackly or anything when in reverse so from that I am assuming the speaker is ok. Does that sound reasonable?
KarimPA
09-03-2015 07:32 PM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
