Ride quality getting worse
Old 07-14-2013, 03:16 PM
OldMike's Avatar
A rough running engine causes vibration, too. I cleaned the part load breather and significantly improved the ride quality. Drove about 100 miles today and still have slight vibration, but not nearly as bad as it was.
Jim...I thought that's what you meant, just wanted clarification. I'm pretty sure I can replace the upper mount bushings myself. That could be my next project, along with the brakes.
Old 07-14-2013, 04:13 PM
Jhartz's Avatar
To break the bushing loose from the carrier, I found a socket that would just sit inside the female but the same size as the male -- two shots with the bfh and it was free. A long bolt with large washer that was larger than the female side pulled it tight. You will need to raise car and put it on jack stands so the jack can be used to lower and raise the wishbone to get the shock stem positioned.
New shocks would fix lower bushing problems.
Cleaning the maf and throttle will also smooth out the motor.
OldMike (07-14-2013)
Old 07-14-2013, 04:16 PM
OldMike's Avatar
I did that last year, but will be looking at again it soon...waiting for the rain to stop.
Old 07-14-2013, 04:25 PM
Jhartz's Avatar
I thought you did. So it is something else. Might retorque the shock nut and upper mount bolts.
Old 07-16-2013, 05:59 PM
OldMike's Avatar
Ok, after another 100 miles, I'm convinced that it was NOT the engine.
Back to the suspension.
scooternva
20
09-27-2023 11:25 AM
XJ8JR
26
08-08-2020 09:38 PM
Forcedair1
02-19-2020 01:51 PM
scatcat
09-15-2015 06:55 AM
02jagstype
09-04-2015 08:20 PM
Quick Reply: Ride quality getting worse
