rides like a truck
Guest
Posts: n/a
Deals, I would tell you to walk around the car and push down on each corner of the car. What you are looking for is a slight rebound of the car. Normally you are using this to check the proper operation of the shocks (ie, car should not bounce more than 3 times, 2 is normal). In your case, what you may see is the car will be pushed down and it will return to ride height with no bouncing. This would indicate to me that you have managed to bend a shock and it is binding up, giving you the hard ride. As for a fix, new shocks. As for a brand, I will let other XK owners give you feedback on that.
If you question the shocks, you can disconnect one end of the shocks and then try pushing down on a corner of the car. In this case, the car should rebound a few times due to minimal dampening. If you are still getting the lack of rebound, then further troubleshooting is needed.
