Rochester pressure valve x308 Cheers, Tony
Did anyone ever find a way to replace the pressure valve with an alternative now the Jaguar and the GM ones are no longer available? H have high pressure when opening the fuel/gas cap? I have searched the forum to my new member abilities and cannot find an answer. Sorry if it has been covered already.
GM 17089068 is AC Delco 214-552 - Vapor Canister Valve ACDelco GM Original Equipment 214-552 | eBay. It seems that the "CAN' and "TANK" ports on the GM/Delco part are swapped 180 deg. compared to the original Jag valve so one should follow the port markings when connecting the GM valve, not its shape.
jadedragon1800
06-07-2011 10:30 AM
