ruff idle after k&N intake problem
Hell all. I'm sure its been posted before but i need help with my jag ASAP. I have a 03 xjr and after K&N intake it ran fine for the 1st few days but went to drive today and it sound like its going to die and i dont want to damage anything. I know i can alway put the factory one back on and hope that fixes the problem but i allready paid for the k&n and would rather use it. If anyone has experienced this before or nows a fix please let me know. Thanks
Some K&N filters are loaded with an oil to catch debris, I think it can effect the mass air flow sensors within the intake tube.
Try and clean the MAF sensor with an electrical contact cleaner spray, you'll need to remove it from the sensor housing with two posi drive screws, wiggle it out.
Another thing it could be is an air leak, so check your install also, as it only takes the induction tube to sit on the throttle body slightly uneven to induce a leak.
Since you are trouble shooting, you start by baselining your configuration
That means putting the stock system back on to eliminate the differences.
If it works, you have a problem with the K&N or the way you installed it. If it does not work, you have eliminated one possible source and can move on to look for other problems, such as the one suggested by midlifexjr.
edit: Quadmaniac has said just about the same thing in his post above.
Check to make sure MAF connector is seated
Check to make sure hose from intake to valve cover is attached and snug Any cracks etc?
Check to make sure the intake pipe is tight to the throttle body
Check to see if the vacuum tubes under the air filter box have been disturbed/broken
Check CPS/connector to see if it is dirty...
The fuel rail does seem to be a good place to check since the car ran fine for a few days....
Also check fuses....
All of the above should not take more than an hour and will eliminate alot of possibilities.
1/ when turning the ignition ON, pump #2 energize for a few seconds to built up pressure and then is turned off.
2/ Pump #1 in turned on at cranking and stay on.
3/ Pump #2 is turned ON at about 4000rpms to add fuel
4/ If pump #1 is defective, ( based on electrical load, not fuel flow) pump #2 stay on after step #1
thanks for the input dsnyder, i have checked all the hoses and everything is snaped on tigh. The hose going from the intake to the valve cover had some oil in or around the end that ataches to the valve cover. is that suppose to have that? i thought about spraying the MAF cleaner on the contacts of the plug for the sensor but wanted to make sure it wouldnt hurt it first. the little red light on the dash was on before withe K&N but went off after i put the factory one back on then after a few tries of starting it the red light came back on but im not getting any other lights or warnings.
No i havnt done anything with the crankshaft position sensor but will add it to the list of possabilities. any advice on how to clean or replace it. the only diagram i could find of it shows its on the back side of the engine near the cabin and looks like it might be hard to get to.
ok guys my mechanic has been looking it over and cant seem pin point it. I checked all fuses under the hood and all good. he said the fuel pump dosnt have any drop in electrical current he is also going to check the fuel pressure. any other advice or ideas i could go over with him? i need all those years of jag experience from everyone please. Thanks
