ruff idle after k&N intake problem
Old 08-23-2011, 12:44 AM
sparkenzap's Avatar
Received 1,064 Likes on 867 Posts
Jag0man.
Actually this should be a prety simple one. The real problems requiring "those years of jag experience from everyone" arte when an intermittent snag gets you.
Step back for a minute- although the problem was reported to have come after the KN folter mod, and that was a good place to start using the "what happened last" troubleshooring technique, that is the only real reason to suspect the MAF.
Are you getting fuel pressure?
Do you have a CEL?
Have you looked at the fuel for water, while doing the pressure test?
What are the resukts of an engine compression test?
I suspect you will have determined the problem before you have completed these standard diagnostic procedures.
Old 08-23-2011, 09:31 AM
Gus's Avatar
Gus
Gus is offline
Received 2,213 Likes on 1,702 Posts
Did you have any OBDII code prior to or after. If not plug in your reader, start the car and try to duplicate the red light flash on the dash then see if it captured your fault. If you are revving the car in “N” ro “P” the car has a limiter to prevent it from revving over I think 3000rpm. Then check the TB plugs, clean and tighten them.
Old 08-23-2011, 06:00 PM
Jag-man's Avatar
thanks again for the sugestions i fowarded them to my mechanic. gus no i dont have a reader, i need to get one though. TB plugs??
Old 08-23-2011, 07:40 PM
Gus's Avatar
Gus
Gus is offline
This is what i am talking about TBoddy
Old 08-23-2011, 08:08 PM
Jag-man's Avatar
gotcha. thanks gus
Rivguy
12-04-2020 07:55 AM
Kevin Burnaby
06-28-2020 08:04 AM
dsnyder586
04-04-2019 02:38 PM
Thang Nguyen
10-12-2015 01:25 AM
Bowman
09-03-2015 03:17 PM
Quick Reply: ruff idle after k&N intake problem
