Sagging headliner
This is a recurrent topic, but I have been looking if anyone have tried the kit on Amazon ( guess it is in more places) were you screw the "button" into the roof. I guess it is a plastic inner roof between the steelroof and the filling before the liner.
Link to product on Amazon ( it the swedish version ) https://www.amazon.se/Homtone-Takrep...s%2C114&sr=8-3
Have a lot of other stuff to attend to the car, and a swap of the headliner would set me back approx 600 USD here, but would still like to "fix" it now when spring is here
Tia o/
/Markus
Tia o/
/Markus
Markus x308 3.2 (04-08-2022)
The following 2 users liked this post by Jhartz:
Markus x308 3.2 (04-08-2022),
Noah (04-10-2022)
QUOTE=Markus x308 3.2;2513350]This is a recurrent topic, but I have been looking if anyone have tried the kit on Amazon ( guess it is in more places) were you screw the "button" into the roof. I guess it is a plastic inner roof between the steelroof and the filling before the liner.
Have a lot of other stuff to attend to the car, and a swap of the headliner would set me back approx 600 USD here, but would still like to "fix" it now when spring is here![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Tia o/
/Markus[/QUOTE]
Tia o/
/Markus[/QUOTE]
I have done my head liner by removing the actual fabric from the roof you have to take some side panels sun visors / alarm sensor /rear lights , carefully you slowly pull it away from the roof, there is quite a lot of old foam comes of,once all removed i used a hand wire brush to clean the roof of all its old foam and also some wire wool again messy , on the fabric i used a steel pot cleaner and soft brass wire brush , i then washed it and hung out to dry. To re attach i used carpet spray glue has to be a clear one masked the windows and other items and slowly started in the drivers following spray glue instructions and used a new dry sponge to push the fabric to roof i did not put a foam backing just straight fabric onto roof board been n two years now and still not saggyy
Markus x308 3.2 (05-02-2022)
jacobwilliam1
General Tech Help
11-06-2009 05:04 PM
