Scraping/Grinding Noise from Engine While Accelerating
Hello all,
I'm attempting to diagnose a symptom that has recently arisen in my 2003 Jaguar XJ8. The car has 84,000 miles on the dial.
I have a scraping/grinding noise coming from engine bay while accelerating upon start-up of the vehicle. The noise will dampen/dissapear after driving for 20 mins or so. Also, it may or may not be unrelated, but I do sense somewhat of a power loss when driving the vehicle, and shifting of gears is not seamless (it will lurch when shifting from 2nd to 3rd gear).
Has anyone had a similar issue? I have a feeling it may be a lazy tensioner. The noise does appear to be coming from the engine compartment, as you can take a stethoscope and hear the scraping mildly when idling. Any help will be appreciated.
BTW, I used Valvoline Multi-Vehicle Import, and I see some here and at the BMW forums are recommending Max Life ATF for the ZF transmission.
Also, on another note, I do have a noticeable shudder with a wheel shake when I reach speeds of 52-60 mph. Seems related to the TC lockup, but not sure if doing a proper flush and filling with Max Life ATF might alleviate these problems. Any suggestions?
innzane
09-02-2015 10:08 AM
