Searching for rear seat belt trim,
King Charles (04-04-2017)
https://www.jaguarclassicparts.com/uk/part/HNC7108ADSDZ
Color match ? If not spray with latex paint only and in mixing color it will change as it dries so you would have to spray sample items a couple of tries . Latex washes off with water so on the final on final part spray it washes off with water if it runs . Surface prep is important as there is probably a oily film on it . soap and water and a toothbrush as a solvent beyond rubbing alcohol may desolve textured surface .
Will be doing it to my X300 different shaped parts later like the sun damaged seat belt tongue plastic after cleaning the fabric / strap
King Charles (12-25-2017)
