Seat memory - missing potentiometer
Hi
I finally took the time to look into the seat memory malfunction, assuming it would be the common problem with the potentiometer.
After removing the back cover, I realized the issue is simpler : there is no such element.
I'm guessing that at some point, either the seat was replaced or the door itself.
Anyhow, I suppose that to restore the functionality, all I require is mounting this potentiometer. Part number is JLM21119 if I'm correct.
Can't seem to find it on sale anywhere however, except at a crazy $250.
Any hints?
Any hints?
Here's another # to try.. JZM100007 ...but its also a discontinued item. It also comes up as a nut spring depending on the site.
Sounds like your going to have to go recycle yard hunting if you don't want to pay $250? But compare it to how many Euros it is on this German site.... https://www.teile-profis.de/page_1_3.php#oeformo ...$250 is a steal.
Tiberious
02-29-2012 06:42 AM
