seat rail - floorpan nut disappeared
sigh ... jaguar does it again!
There is a torx head bolt that goes through the seat rail at the front. It goes into a captive nut or some other threaded fitting in the floorpan cross brace.
Unfortunately, removing the bolt seems to have also allow the nut to disappear. The bolt was not tighter than normal, and did not require anything special to remove. It backed out completely normally. But, the nut has just disappeared into the cavity somewhere. Found that out when it came time for reinstallation.
Does anyone have any suggestions as to an alternative fastener since the rear side cannot be accessed to use a plain nut?
plums (10-09-2011)
Really? That would be great news!
I'll have a look around, and another look at the remaining one to see what it looks like.
But from memory, the 2 on the passenger seat runners and the remaining 1 on the driver's seat runners seem to be threaded beyond the face of the floorpan sheetmetal.
ericjansen
12-19-2021 12:20 AM
Poet
10-06-2015 09:40 PM
Andrew Fanshawe
09-14-2015 07:40 PM
