Secondary tensioners question
Old 08-20-2018, 04:55 PM
buttercup26's Avatar
Default Secondary tensioners question
Just received secondary tensioners set and installed 1 side. They don't seem t keep chain as tight as one I replaced. Is this to be expected?
Old 08-20-2018, 06:47 PM
RJ237's Avatar
Received 2,819 Likes on 2,246 Posts
Yes. I assume you pulled the pin. Once the oil is up to pressure it will be okay. Note that you are supposed to turn the engine over with injectors disabled to get oil pressure in the system.
buttercup26 (08-21-2018)
Old 08-21-2018, 08:56 AM
avern1's Avatar
Received 1,319 Likes on 1,004 Posts
The easiest way to shut off the fuel to the injectors is to hold the accelerator pedal alway down on the floor before and duriing cranking. This shhuts off fuel to the injectors and allows cranking to build oil pressure before first start up.
Old 08-21-2018, 06:55 PM
Great, ws studying how to disconnect injectors 2 great tips.
Namor
01-21-2012 09:12 PM
Roos50
General Tech Help
01-18-2010 06:45 AM
wilson18067
07-22-2008 06:54 PM
JimT
07-08-2008 04:51 PM
Quick Reply: Secondary tensioners question
