security lock module replacement
You might try drying yours. Air conditioned space overnight. Reinstall and do a hard reset (a thread, updated by Jim Lombardi, explains how).
If you need a new one, find the right number and right freq (mhz) to match yours and hunt on eBay. I bid down the price and got mine fairly cheap. Then, an option is to send yours off for rebuild and either reinstall it or put it up for auction.
But, as Ross noted, you must reprogram your key Fobs.
XJ8 (2000) Security Locking Module
I have an XJ8 (2000 [x Reg]) and think the SLM is up the creek. The left brake light stayed on even with the ignition off. We by-passed it by wiring it into the right brake light. Its been okay for a month or so but now the right one is staying on. The centre brake light still works okay. The SLM code is LNG 2600JB. SLMs with this code seem to be few and far between. EuroJag on ebay have 5 but they're £125 each. That about £100 more than others up for sale. A few questions: Can I use an SLM with a different code? If I buy one - is it just plug and play? From the threads it looks like I may have to get the key fob recoded. Where would I get that done? Thanks in advance for any help. Steve
2001 and newer Security Locking Module
This is what I did and it worked great, my door locks where starting to act up on my 2000 XJR and my Keyfobs where starting to be intermittent. I also tried changing the batteries and cleaning the contacts and the problems grew worse! Second problem I was faced with was the new Jaguar Keyfobs 2000 and older where almost $400 each! The 2001-2003 XJ keyfob can be replaced with a pair of $10 Keyfobs off Ebay.
I bought a security locking module from a 2001-2003 XJ and installed it in my car then I programmed the $10 Ford Keyfobs and it works great.
If your Keyfobs are original it's just a matter of time before you will need to replace them, now is the time to put updated SLM.
2001 jaguar xj keyfob programming maybe someone can post the link for the procedure to program the fobs, very simple using the ignition switch and high beam switch.
Steve10 (08-04-2017)
Xj8
I have a 2004 XJ8 Jaguar. Where is my security alarm module located? Thank you.
I believe you're in the wrong sub forum, but if they didn't move it between the 2003 model year (X308) and 2004 (yours), then it's in the trunk to the rear of the battery, underneath the fuse/relay module.
Correction on that it wasn't in the roof ceiling either. That's what someone has said, but it wasn't there. Sorry for the inconvenience. Stop don't do that. So I still haven't found it yet.
Martyn Musch
07-24-2023 04:01 PM
jimlombardi
02-11-2014 07:16 PM
ixj8it
11-07-2012 11:45 PM
