security module question
so I have a bad security module on a 99 xjr lnc2600hd is the part number. I have found on the internet a 2003 xj8 that is being parted out but could not get the info from the guy if they have the same module. Just wondering if anyone knew offhand if the two share the same part number to save a 70 mile trip. thx in advance
You need to get the same last 3 digits from the VCATS (vehicle configuration and technical specifications) label in the boot from BOTH cars to match. Look in the boot near the spare wheel on your car for SLCM and record the part number and the /suffix and then ask the person who has the donar car to do the same. If they match you are good to go as far as compatatibility goes but you will need to configure the module to the vehicle. WDS,IDS or some other computer to configure the modules!! No guarantees if the numbers don't match.
good luck
bob gauff
good luck
bob gauff
trosty
26
12-18-2022 06:40 PM
FS[Western US]: FREE- 99 XJR ECM and TCM
XJsc-guy
09-25-2015 11:09 AM
abonano
25
09-25-2015 10:43 AM
