Self applied ceramic coating
2003 black XJ8. The roof has recently started showing sun baking. Clear coat not lifting but lost shine and doesn’t feel smooth. Paint on bonnet and boot much better. Just got done doing a high quality black wax job. Roof looks much better but still not good. Anyone do a ceramic coating self application and can recommend a brand?
Received 2,832 Likes
That “lack of smoothness” might just be an accumulation of contaminants on the surface and some time with a clay bar would be the quickest/easiest way to find out.
If the previous owner wasn’t particularly tall, the roof is the last panel that would have received any attention. I know someone who imported an older Daimler from Japan they had been owned by a hotel and you could see your image in every body panel except the roof…. a good claying and its first wax in a long time worked wonders.
Hard to tell when not looking at it in person, but I think I would wet sand it and buff. You might be able to knock off enough of the baked clear coat and get it back to a nice shine. I definitely would do some kind of surface prep vs just applying a ceramic coating. I don't think that will do anything. A clay bar as suggested above is a good idea too. Some pictures of what you're seeing might help as well.
My first choice would be to select the worst looking/feeling area and use good ol' fashioned rubbing compound.
I use the Turtle wax brand with satisfaction. After a bit of scrubbing then I use polishing compound of the same
brand, and once i get the finish back, I top it off with Turtle wax paste. The only car that did not work on was a
1977 Lincoln Continental whose roof paint was so thin, the compound broke through to the primer. I would
expect that Jaguar paint is much thicker and less prone for that malady.
seemed to demand a bit of aggressiveness. If you know what you are doing, you don't have to rub hard to
get past the oxidation described without harming the surface. If in doubt use a polishing compound first to
see if you can remove the oxidation.
