Serpentine Belt blew, how to replace?
No, the S/C belt requires removal before you can fit the acc belt.
The simple way is to remove the fan assembly which is 2 bolts and a couple of zip ties - this gives the access space to remove both belts. The fan connector is located on the bottom lhs.
A half inch breaker bar fitted into the S/C tensioner pulley body and swing the tensioner so you can slip it off, then you can fit the Acc belt.
Hope this helps.
Hope this helps.
2007 Rick
12-15-2015 02:50 PM
02intrigue
10-25-2007 08:46 PM
