Shifter knob and faceplate (R, D, P, Etc..)
Can anyone help with the shifter knob removal in my '03 xj8? I thought it just unscrewed, but it seems extremely tight, and I don't want to break the shaft.
Also, the faceplate on my J gate shifter is cracked and I want to replace it. Can it be "peeled" off or removed somehow and replaced with another plate?
These are trivial things, but I just bought this car and want to make it as nice as possible, it's a real beauty!
Many thanks for all and any help!
3timejag (07-14-2017)
The shifter knob is only screwed in, but I've seen some with threadlocker applied, so you may have to use a bit more force to remove it.
To replace the faceplate on your J-gate I believe you have to remove the whole assembly. As I recall it was a simple job once you have it all out. Check out this thread, it might be helpful:
https://www.jaguarforums.com/forum/x...cklight-75330/
While on the job check also if the backlight works, it will save you doing it all again
