shifter stuck
Old 01-05-2012, 09:33 PM
vincent661983's Avatar
Default shifter stuck
just happened today, shifter stuck and I could not shift to "D" all way down as the "D" did not lit up.
other posts stated that had to do with the linkage, is it? hopefully an EZ fix,thank you
Old 01-06-2012, 06:25 AM
DavidN's Avatar
There is a black plastic "screw" on the left side next to the shift knob on top of the J-Gate.
Unscrew that plastic screw and beneath there is the shifter lock latch.
With a screwdriver (or something long and round) you can push the safety "switch" that locks the shifter in "P".
While pushing the "switch" down you should be able to shift out of "P".
If that solves your problem - the safety switch/latch is normally operated by a solenoid. That could be the culprit.
HTH!
Cheers,
David
Old 01-06-2012, 07:58 AM
Thanks,David. I will try over the weekend. I could actually shift to D but the colume does not actaully "click" in the right gear as the D word does not turn red. Car is like running between N and D.
Car was towed just a block , I don't know if it casued any damage. A little fraustrated. Thanks helping me and good weekend to come
Old 01-06-2012, 11:20 AM
pdog2000's Avatar
Did the tow truck driver put the car in neutral and how did he tow the car...front or rear wheels on the ground?
Old 01-06-2012, 12:29 PM
DavidN's Avatar
Ohoh, that sounds not good.
Sorry, no idea here ...
Old 01-06-2012, 04:30 PM
Boomer from Boston's Avatar
It is **possible** that all that is wrong, is that that the shifter cable is out of adjustment for some reason. Basically, you have to first get the console out of the way. Then you shift the transmission to get the gearbox into neutral. Then you adjust the locknuts on the right side of the shifter assembly to get the lever to be centered on the N position. After which the console should read D when the tranny is in drive. This is all explained in detail in the JTIS and in other threads on this forum.
Old 01-06-2012, 06:54 PM
test point's Avatar
Received 1,111 Likes on 932 Posts
Here is a video link that describes how to get to the cable adjustment referenced above thanks to Rev Sam.
Jaguar XK8 Center Console Removal - YouTube
adam699
10-13-2015 05:53 PM
Johnken
10-02-2015 10:12 AM
Johnken
10-01-2015 05:07 PM
Lawrence
XJ40 ( XJ81 )
10-01-2015 08:36 AM
Quick Reply: shifter stuck
