Shock absorbers!
Shock absorbers!
I am thinking it may be time for new shocks, I am going to be replacing lower ball joints, sway bar links, and sway bar bushings. I think I should probably also replace the shocks, going to start with the front, and then the back.
I don't really want to spend more than $60 each. I found some KYB Gas-A-Just mono tubes for about $54 each, but I have read these may be kinda stiff?
I really like the OE ride quality. I love the floating feel of it, but I don't want to spend a lot of money on shocks. Has anyone ever put the KYB Gas-A-Just shocks on their Jag? I'd be really curious to know what the ride quality is like.
Thanks!
Thanks!
If you don't want to upset the ride buy oem, if you want to save money buy them secondhand - Bilsteins are expensive, but with most things in life you get what you pay for!
There's cars being 'parted out' on here, buy the shocks!
I've read on here that KYB last about 12 months, nowhere near the quality the car requires.
capncraigagain (10-15-2017)
Lots of threads in this forum. AllShocks, a division of Turner Motorsports, has the best deal I could find on Bilstein (go with the Bilsteins!).
Noting your other thread on front end noise and ball joints, it is quite likely you need upper shock mounts as well (again, tons of threads on DIY to buying complete sets $$$$).
Yes. The R models are more sportier. But the VDP and XJ8 and XJ8L use the same shock.
Confirm by: Call them, their phone clerk is exceptionally helpful and will answer these questions.
Use eBay or Amazon to find the best deal on upper shock mounts.
Most likely lower or upper shock bushings. Easiest way is to replace the shocks, they come with new lower bushings installed -- labor is cheaper than removing the shock and punching out the old, dried out bushings, and you get new shocks (although, as Sean has described before, Bilsteins hardly wear out).
You might also be hearing some body flexing . . . Or creaking in the exhaust system. Tracking noise is a labor of love in old cars (or **** retention -- without hearing the noise, hard to say). Or bad V mounts or front body mounts . . . Lots of threads.
I have new (2 years ago) neoprene upper mount bushings: below 30*F they rattled their *** off the last two winters: in the 90s now, dead silent. It's a hobby!
monroe's haven't always been this way, but in the last five years my experience has been that quality control has gone way down hill.
I worked at a part store, and they got returned ALL THE TIME for failing. Which is kind of amazing, because I get the impression a lot of people would just keep driving on them and not even know they're bad. They just assume "well, i just had them changed" and figure they must be good.
I've only had good experiences with KYB. Some applications were better than others for how the ride was affected, but rarely fail early.
They're stiff/firm however they are very comfortable to drive on even very rough roads. Ever ride in a Buick? They're smoother than that by a long shot (Buick ride quality is mediocre at best anyway).
So far for half the cost of the Bilstein's I really like the KYB Gas-A-Just.
I found two different green Bilstein shocks for the x308 XJR. Which set is best? The 20-070502, or 24-023726.
https://cart.bilsteinus.com/results?...76998327672829
