Should both cooling fans come on when I use the AC
Don B (06-14-2019)
The slow mode kicks both fans on at 174psi A/C pressure, fast mode (both fans again, but full speed) kicks in at 326psi. If A/C high-side pressures are below 174 (which would happen if outside temps are relatively cool), both fans should never run. I would suspect that one of your fans is inoperative.
https://www.jaguarforums.com/forum/x...r-shop-199844/
Don B (06-14-2019)
FS[SouthEast]: Uprated Radiator Fan & Fan Cowl Assembly for S1 E-Type
SCMike
09-17-2016 07:56 PM
AltaHeights1
09-07-2016 04:49 PM
Tink
09-01-2016 01:04 AM
