Should I add H2O?
The coolant should be right at the bottom of the neck. In other words about a half inch from the outer lip, so you are definitely low.
Water is fine, certainly better than running low on coolant. If you are running the specified Dexcool, it should be available almost anywhere including gas stations.
The problem with adding straight water is that it dilutes your mix. Much better to always carry a quart or so of premix or full strength.
Thanks for the help, I decided to get up early and get some Dexcool 50/50 from AdvanceAutoParts -- ordered online, picked up on the way to work. Drove 20 miles to work without adding the coolant. Did not get the low coolant warning on the way to work. I filled it after it sat in the parking lot for a couple hours. Will have to keep an eye on it to see if I have a leak somewhere. I've had the car since April and don't remember EVER checking the coolant level -- shame on me. So I don't have a baseline to work from.
Received 2,190 Likes
Hmmm, Brutal, this gives new meaning to 'flushing' your cooling system
![Icon Lol](https://www.jaguarforums.com/forum/images/smilies/icon_lol.gif)
SD96XJ6L
11-05-2015 10:47 AM
davidboger
10-01-2015 10:13 AM
