Should I attempt coolant flush green to orange on 2000 XJ8 with 200k miles?
I bought a 2000 JX8L in November 2022 with 191k miles on it. I've made some small repairs myself and fixed things like bulbs, the cupholders, and I recently learned to change the oil.
And it has green coolant... not sure how long it's been in there and I've read enough after a low coolant alarm that I know it should be orange. The coolant levels were fine, I think it was the sensor.
The assistant manager at the shop where I change my oil recommended that I do not attempt the coolant flush myself because of the high mileage and the potential for leaks afterwards or other issues. He recommended I take it in to the local shop that services jaguars (Autobahn Auto in Hampton VA) so if something goes wrong they're on the hook. Autobahn quoted me $215 for the flush.
I planned to follow this thread's coolant flush steps, and I'm worried if I take it somewhere all the green coolant might not be fully flushed out before they refill with the orange.
So, with my novice repair abilities and plenty of time, should I try to flush it at home? Or do you think I should take it in and hope for the best?
Mine had green antifreeze when I got it. With various repairs over the years that have necessitated draining and refilling the antifreeze now and then, I have always just replaced it with green, and have never done a complete flush. If I were you, I would probably drain it at the radiator, refill with distilled water, run it for a while, drain it again, repeat a couple of times. Then I’d refill it with green. That way it doesn’t matter if you get every last drop of green out.
that said, I run green coolant as thats what was in my car. As long as you change it every 2 years, its no big deal.
On my 2006 STR I went the opposite direction and changed it from the orange antifreeze to the tried and true Green Prestone. I don’t need long life antifreeze and plus I’ve had bad luck with that orange dexcool stuff in the past. The green seems to work just fine I just don’t expect to go 100,000 miles on it. All I did to change was just did several distilled water flushes over a period of weeks make sure I got every last bit out and I’ve got no problems
Jhartz (08-01-2023)
I would not rely only on the coolant colour to determine what type (formulation) it is. The standard glycol based coolants can be blue, green, lime green, red and even orange colour. The Organic Acid Technology (OAT) coolants seem to come only as orange but I am not sure. What is important is to verify whether the coolant is Glycol based or Organic Acid based. The two CANNOT be mixed and, if one is switching between the two, a thorough flush must be done.
nilanium (08-02-2023)
After a lot of research on the called out coolant specs and compatibility when I was doing a flush and timing chain job on my xjr when I got it, I ended up settling on prestone universal coolant, it had a callout for one of the standards required by jaguar. Also you can buy it anywhere...
6 years and 55k miles later and I haven't seen any issues caused by it.
Would probably avoid the OAT coolant unless specifically required. I know the jag coolant specs changed a few times over the years, I think aj27 engines call out a different standard but the Prestone may still meet that
Jhartz (08-02-2023)
alistairolsen
12-07-2020 07:01 AM
