Should I blow $2k to blindly rebuild tranny?
I'm at a dilemma, my tranny slips occasionally but in the meantime it's getting me from A to B without issue. I've got no codes or leaks or obvious cause. Mechanic says the only option to repair is to open the case and the labor of that already warrants going all the way and just rebuilding the transmission (quoted to expect in the vicinity of $1800 USD)
What should I do?
My jag is a VDP with beautiful custom suede roofliner but it's also a high mileage NYC-car (lots of aesthetic imperfections everywhere). There's nothing else mechanically wrong with the car and all of the suspension and related wear items have been recently replaced (total cost of about $900.)
What should I do?
Symptoms imply the torque converter is slipping.
500 euro is the going rate for a rebuild? That info is greatly appreciated
Ohhh, so that's 500 euro plus 6 hours labor, that's a big difference in $. (I can't do the labor myself)
Never blindly repair anything. If a diagnosis cannot be made from direct inspection or documented testing procedures, then a process of elimination is in order from cheapest first to most expensive last. Perhaps its just a fluid problem or maybe its a problem with the valve body, which can be replaced/rebuilt without removing the transmission. Take it to another shop, finding one that deals in european cars or Jaguars specifically, and get a second opinion before you spend any more money.
Transmission shops are notorious for just wanting to rebuild the whole thing. If they just repair it then its still a high mileage transmission and something else could break inside it the day after you get it back. If they rebuild it completely, not only have they charged you a lot more money, there's a lot less chance that you're going to bring it back with a complaint inside a month. Its in their best interest to talk you into a full rebuild. However, its probably in your best interest to play the odds, especially if its an old car that isn't worth much more than the cost of a rebuild anyway. Good luck.
k-man (06-07-2017)
Tomorrow he's gonna check the fluid and I'll have him stick some Lucas Transmission Stop Slip snake oil in there and pray for a miracle.
CharlezO, $900 includes parts & labor for motor mounts and all 4 shocks + lots of other parts. come to NYC and I'll refer you...
The problem you have is you are still driving the car around, in heavy city traffic too. Your car clearly has a transmission problem, and with all the documented issues regarding the transmissions on these cars I'm surprised you're still driving it around. Every mile you drive it in it's current condition will be making whatever problem you have worse. You've told us that it's a high mileage box with the original fluid in, which will not have helped anything. One good thing is you haven't had the "Gearbox Fault" message on the dash yet, so you could be in luck.
You should at the very least change the fluid and filter.
Fyi, I've got just one car, so it's gonna be driven so long as it keeps driving...
I see Jags transmissions on ebay going from $600.00+s/h to $1200.00+s/h from low mileage cars to ???mileage, it is all luck of the draw, I had my XJR transmission rebuilt for $2595.00 by aamco a yr ago and it works great (w/high mileage 147000k I didn't want to have any surprises) I weighted the option of pymnts for new car vs repairing my XJR. My car won out and no 4-5 yr car pymnts......just my two cents.....
Just be aware your symptoms could very easily be caused by a low fluid level.
Change the fluid now and DO NOT add anything to it. Since you don't have any transmission error codes you might be OK but I would still change the fluid.
Yes you are making worse with every mile you drive. The 6 speed ZF is a good transmission but not a great one and will take a good bit of abuse. So don't delay in checking/changing the fluid.
I think you got your money's worth if it's still on original fluid at those miles!!
![Icon Lolsign](https://www.jaguarforums.com/forum/images/smilies/icon_lolsign.gif)
Seriously though, having the level checked later this afternoon, going to add the Lucas Snake Oil regardless because I already have it and am hoping for a miracle. The Lucas Transmission Stop Slip can't hurt, right?
I'm a purist, my Jag has all the original fluids, even the oil! ![Icon Lolsign](https://www.jaguarforums.com/forum/images/smilies/icon_lolsign.gif)
However, if you want to ignore the advice from myself and others regarding changing your probably low fluid and contaminate the already very old fluid with a "magic product" then that's entirely up to you.
Ugh, they opened the filler and the fluid squirted a bit out (was totally full) and was a relatively clean green color. So nothing wrong means the cause is still a mystery.
Mechanic also warned against the snake oil, so haven't added that in... He also mentioned that it can't be added via the hole, only by removing the pan, due to how extremely thick it is.
