Side Mirror Gasket/Seal
Looks familiar... that sad rubber triangle.
If you scroll down to the last two pictures, you can see what that triangle looked like on my X-Type:
http://jagrepair.com/images/Electric...al%20Guide.pdf
And you can see, how I fixed my triangle, however mine did not look that bad...
But I can still see hope for your triangle: You could use a 1mm thick rubber sheet and cut it to the triangle size you need and glue your remainder (after you trimmed the damage off a bit) onto the new 1mm triangle with black roof silicone... - that's what I would do...
Yes. And I strongly assume that rubber is damaged due to heat (sun). My rubber triangle was damaged only where the rubber had contact to the sheet metal of the door - those undamaged surfaces had contact only to plastic, which wasn't getting at hot as the sheet metal.
I bought my 1mm rubber on a roll - from either aliexpress or ebay. Just re-use of the OE part what you can use and glue it with black silicone onto a rubber sheet of your selected thickness - probably 1mm, but it comes in thicker material thickness as well, if you want that.
Btw.: The exterior door handles of my '98 X308 do have rubber between the handles and the sheet metal of the door, but all that rubber had disintegrated. I replaced that all - I just cut out new parts from rubber sheets - I think 2mm sheets.
Peter_of_Australia
09-01-2023 07:06 AM
Yellow series3
05-06-2019 11:27 AM
