Sideview mirror adjustment
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Took bessie out from her winter storage last week, and apart from the drivers side headrest not adjusting, I came across a new issue... weird sideview mirror adjustment.
If I try to adjust the drivers side mirror, left-right works correctly, but if I try to angle up, the passenger side mirror goes down, and the drivers side doesn't move. Anyone come across this before?
Two things come to mind: 1) be sure that you have a fully charged battery, and 2) do a reset. It’s always good advice to start with these two simple and common issues, and then go from there. My guess is your battery is weak, but sometimes these cars just need a good reset.
Ok - did that. Checked the battery and its good.
What functions works on the drivers door panel:
- Front passenger window will go down but not up
- Driver and passenger side mirror adjustments
- Last memory position for seats
What doesn't:
- Rear passenger window adjustments
- Drivers window
- Side passenger window up
- Seat memory function
Must be the controller board for the panel?
What doesn't:
- Drivers window
Just found a posting in this forum -> https://www.jaguarforums.com/forum/x...ontrol-218970/
Exact same issue I'm having. Must be the switch panel. I'll have to pop off the door panel and take a look at the circuit board. Switch panels are hard to come by and are $100+USD used.
You can give Jaguar Heaven in California a call to price a salvaged switch pack. They’re a Jaguar specific salvage yard, and I’ve purchased a number of things from them over the years. Having a part number is best. There is probably a number on your switch pack, or else you can find it on the Jaguar Classic Parts website.
Off to eBay I go
