Size of backseat door opening
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Hi everyone,
I own a 1998 LWB x308 and I have to pick up two chair frames with size W77xD70xH67cm and was wondering if this will fit throught the backseat doors (or ar least one of them). Does any one know the largest cube that will fit through that door?
Thank you for helping me out.
I can only do what you can do and and that is measure the opening of my rear doors, but an item of your measurements should fit fairly easily inside the back seat of your LWB. If there is any difficulty at all it would be possible initial interference with the rear of the front seat when angling the item in, but the front seat could be temporarily moved forward for clearance.
It's too big to go in the trunk/boot.
My bet is you would not have any problem fitting it in the rear seat area..
The longest measurement (77cm) would obviously fit lengthwise inside the car, and the LWB/VDP door opening is approx 74cm x 70cm, so the 70x67 item should easily slide in there.
